cnWave System Release 1.2 has been released
cnWave 60GHz System Release 1.2 has been released. Find the firmware and full release notes at
https://support.cambiumnetworks.com/files/60ghz-cnwave/
:point_right: Minimum cnMaestro version should be 3.0.4.
:point_right: Upgrade the External E2E controller first following this link and then the nodes (where External E2E is used)
:point_right: When using onboard controller, its recommended to upgrade the whole mesh together.
Features introduced in System Release 1.2
  • Antenna Alignment
  • DHCP Option 82
  • Monitor PoP Interface
  • Unconnected PoPs
  • Auto Manage IPv6 Routes
  • Ping Tool
  • Supporting IPv4 RADIUS server IP
  • CPE Prefix Zoning
  • Factory Reset Options
  • Additional nodes supported by Onboard controller
  • Show SFP Power Details
Problems corrected in System Release 1.2
Known Issues or Limitations in System Release 1.2
We are currently using an on-premises E2E controller V1.1
The VM is running OVA: 1.0.1-r2 with Patch: 1.1.0-r1
Can we just apply the new patch for V1.2?
Thanks.
Des.
Hi @lightnet-des,
Yes we can apply v1.2 on top of v1.1. Please make sure that you follow the below steps to perform the same.
  1. Update the cnMaestro version to v3.0.4(Not applicable if cnMaestro cloud is used).
  2. Update the external e2e VM with package 1.2.0-r1 as explained here.
  3. Update the PoP device(s) with the 1.2 image
  4. Update all the other nodes with respective 1.2 image
1.2.0-r1 package and 1.2 device images can be downloaded from here.
Hi @vaa100
Thank you for the reply and details on upgrading. We ran into an issue previously where the E2E controller VM needed internet access to update to a new patch version. Is it still a requirement that the E2E needs internet access to perform the patch update?
Hi @lightnet-des
1.2.0-r1 update does not need internet access.
service ssh admin@ is broke
CLISH>service ssh
Unsupported options
##Error Processing Command
CLISH>service ssh admin@x.x.x.x
Unsupported options
cnMaestro cloud still shows 1.2 as “beta” although it is now “recommended”.
Can you confirm if cnMaestro cloud is the beta version, or if it is actually the release version?
I also noticed the service ssh admin@**** not working anymore
Thanks for reporting this bug. Yes, it got broken. Apologies !!
We will fix this in 1.2.1
