cnWave 60GHz System Release 1.4 has been released. Find the firmware and full release notes at https://support.cambiumnetworks.com/files/60ghz-cnwave/
cnMaestro version 5.1.0 (or higher) is compatible with this release
Upgrade the External E2E controller first and then the nodes
When using onboard controller, its recommended to upgrade the whole mesh together.
Features introduced in System Release 1.4
- DHCPv4 client on PoP nodes
- Security banner
- High Availability (HA) support for Onboard E2E Controller
Problems corrected in System Release 1.4
| Tracking number | Product | Description |
| 60 GHz cnWave-4100 | V2000 | After the factory reset of V2000 PoP, the Quick Start UI page showed the SFP interface. |
| 60 GHz cnWave-4110 | V2000 | In V2000 PoP, throughput reduced when multiple tunnels failover. |
| 60 GHz cnWave-4108 | All | Sometimes, L2GRE tunnel deletion failed when the PoP was hosting more than 10 tunnels. |
| 60 GHz cnWave-4212 | All | Enabling the E2E controller failed when the site name or device name had spaces. |
