cnWave 60GHz System Release 1.5.1 has been released. Find the firmware and full release notes at Cambium Networks Support
cnMaestro version 5.2.0 (or higher) is compatible with this release
Upgrade the External E2E controller first and then the nodes (where External E2E is used)
When using onboard controller, its recommended to upgrade the whole mesh together.
This release has no new features.
Problems corrected in System Release 1.5.1
| Tracking number | Product | Description |
| 60 GHz cnWave-4340 | V1000 | Improved the time required to start an IPv4 ping after clicking the Quick PTP button. |
| 60 GHz cnWave-4303 | All | Closed the TCP ports (6969 and 6881) on the Onboard E2E Controller and the External E2E Controller. These ports were used for image upgrade in previous releases. |
| 60 GHz cnWave-4363 | V1000, V3000,and V5000 | The link to CN did not come up when the PoP rebooted with the pop_interface cable plugged out (unplugged). |
