cnWave System Release 1.5 has been released
cnWave 60GHz System Release 1.5 has been released. Find the firmware and full release notes at https://support.cambiumnetworks.com/files/60ghz-cnwave/
:point_right: cnMaestro version 5.2.0 (or higher) is compatible with this release
:point_right: Upgrade the External E2E controller first and then the nodes
:point_right: When using onboard controller, its recommended to upgrade the whole mesh together.
Features introduced in System Release 1.5
  • Auto Channel and Golay optimizers
  • Dynamic Walking PBF
  • Interference Scan
Problems corrected in System Release 1.5
Tracking number Product Description
60 GHz cnWave-3906 All GPS did not update latitude and longitude in the PoP UI when a site was deleted and re-added.
60 GHz cnWave-4197 V1000 The Relay port did not work on a V1000 device.
60 GHz cnWave-4233 V2000 The Relay port functionality did not work when enabled on both Ethernet ports of a V2000 device.
60 GHz cnWave-4236 V1000, V2000,and V3000 A CN MAC address without a colon was rejected in the Quick PTP Setup UI page.
60 GHz cnWave-4237 All The Download POP Onboarding Config feature in cnMaestro should support Management VLAN and BGP parameters.
60 GHz cnWave-4287 All Sometimes, in a CN backup link enabled PMP topology, the DN received incorrect configuration and got stuck.
When will cnMaestro 5.2 be available for on Prem, and will cloud be released first?
Should we not upgrade to 1.5 if we only have cnMaestro 5.1.0-r4?
5.2.0 Cloud was released last week. On prem is expected in Feb 2025.
The front end for Interference scan, Channel/Golay optimizers are available in 5.2.0. Other than that, there is no restriction in upgrading to 1.5 with an older cnMaestro.
It is recommended to use 1.5 in maestro greater than 5.1.0 maestro
