cnWave System Release 1.7 has been released
cnWave 60GHz System Release 1.7 has been released. Find the firmware and full release notes at https://support.cambiumnetworks.com/files/60ghz-cnwave/
:point_right: cnMaestro version 5.2.5 (or higher) is compatible with this release
:point_right: Upgrade the External E2E controller first and then the nodes
:point_right: When using onboard controller, its recommended to upgrade the whole mesh together.
Features introduced in System Release 1.7
  • 60 node support on onboard controller
  • Additional JSON fields in POP onboarding configuration file
  • DOS Attack resilency
Problems corrected in System Release 1.7
Tracking number Product Description
60 GHz cnWave-4512 V1000 Resolved an issue where the V1000 Relay did not function unless Layer 2 was disabled on the unit.
Has anyone upgraded their network to 1.7? Any noticeable improvements or issues found? Always like to ask before going forward myself!
No news is good news, we can see from cnMaestro hundreds of networks are using 1.7 and no reported tickets on this version.
OK I know I’m tempting fate, but I would rather provoke a response.
In the meantime, the Factory and DC’s have all switched to 1.7, so all new kit will be at this software version going forward.
We did go ahead with the upgrade and did not have any issues.
