The PTP 450i radios default out of the box to mode: timing slave with country code: none. This makes sense of course. However, when I do the following:
- export a configuration file from a PTP 450i configured as a timing master
- reset the same radio to factory default
- try to import the same configuration file
It fails. The error I get is:
- 01/01/2016 : 01:30:28 UTC : Info: Variable bandwidth reported error 3 while setting
I'm currently unable to start with a factory default PTP 450i timing slave and to load a timing master config file on it in one step. The only way I can currently accomplish this is to:
- reset the radio to factory default
- manually set mode to timing master mode and select a country code
- reboot
- then I'm able to successfully load my timing master config.
Is there any way around this? It seems like it must be a common scenario....what if I had a configuration backup of a timing master, and the radio had an equipment failure. I would then want to take a new default unit and make it identical to the original unit from my backup file - without having to manually set country code and mode first.
