I'm doing some test using Cnmaestro, after successfully onboarding my first E400, i get an error message when I try to push the configuration, as shown below, could someone help me please?
After making some changings I managed to get "only" invalid IP Address -.-
Thx
P.S. my test set consist of my home modem/router, connected with 1 LAN port to my pc and with another LAN port connected to the E400
however in the last few days I got the invalid IP address error (the invalid character disappeared), but I do not know why since I didn't touch the IP address
Unfortunately I keep having the invalid IP address message when pushing a config, don't know why
The strange thing is that logging into the E400 using GUI the logs show that some changes has been made, but for example the radios still do not work; I think that parameters such as name and other are pushed successfully but not others, like radios settings
I had the same issue with the cnMaestro cloud (Version1.6.3-r1 according to Cambium web site) and got this error when trying to set DHCP / VLAN gateways for 2 x SSIDs across 2 x E410 APs. I ended up logging in locally to the problem AP and removing the VLANs, then removing the same from the cloud config, then setting it back up from scratch again and it came right.
I have the same problem, 16 accespoints with same messages "Not In SyncSync Configuration Configuration failed: interface_vlan:Invalid IP address string",
Logs:
020-05-04 04:39:00 475 wifi.c:1768:platform_set_cns_connection_state: New Connection_state Connected(6) 2020-05-04 04:39:00 475 wifi.c:294:platform_set_config: Object based configuration update initiated 2020-05-04 04:39:00 475 wifi.c:302:platform_set_config: Bad config request [interface_vlan:Invalid IP address string] 2020-05-04 04:39:00 475 device-agent.c:1572:handle_cns_msg: Sending MSG_CONFIG_UPDATE_FAILED to cnMaestro 2020-05-04 04:39:01 475 log.c:207:start_cns_logging: Send log history (10 lines) 2020-05-04 04:39:00 475 wifi.c:1307:set_log_level: syslog severity=7
I 've update firmware to last version already, also i've made factory reset, delete all wlans, load config file from working in-sync APs, .. 16 not in sync and 6 sync... all the same model cnPilot e410.
I did it as you ask me, I've cloned AP-group "oficinas-Bogota", and claim an access-point to this group, first I tried to push the same configuration with all my vlans,... I get the same error message. So Then i try to push the config only using 1 vlan, the one that actually works CCB-CORP from the clonegroup.. .I get the same error message, im attching to this message an image.
I want to be more specific, rith now the problem is that vlan 16, is not working good.. all my clients connect and lost connections in random time, or sometimes they connect to wi-fi without internet access.
All this problems start 2 or 3 week ago when the building power go out. I hope this is not a hardware damage, is it posible?.
I have deleted VLAN 16 and recreated it and pushed the config on the clone AP group and also on the actual AP group, currently all APs which are online are In-Sync.
