Configuration syslog port
Hello
i install a graylog, as a log server and i had to change the port for sending log menssages. I can’t find a way to make my epmp 2000 and epmp 3000 send the log menssages to the port i want.
Hola @Nicolas_espana,
you can do it via CLI:
E3K_cs>config show | syslog
syslogServerIPFirst                      192.168.0.71
syslogServerLogCLISH                     1
syslogServerLogDA                        1
syslogServerLogMask                      255
syslogServerLogToWeb                     1
syslogServerPortFirst                    514
syslogServerPortFourth                   514
syslogServerPortSecond                   514
syslogServerPortThird                    514
3K_cs>config set syslogServerPortFirst 777
E3K_cs>config commit
E3K_cs>config show | first
Also you can do it via SNMP and CnMaestro template
Thanks for your help, I followed the configuration you gave me, but the syslogServeralogMask does not change from 15 on one device and on the other it stays at 127.
In addition, although I assign the IP and port that I assigned to my server, the log messages still do not arrive, I am using graylog server
