How is the pinout of the cnReach N500 DB-9 to RJ-45 adapter?
What parameters are set in the terminal emulator?
Hi, the RJ-45 pinout on the cnReach radio serial port is below. To connect to a laptop we normally use a USB to DB-9 Serial cable to connect to this RJ-45. The default terminal settings for a console login is 115200, 8N1.
NB-N500005A-US |
N500 RJ45-DB9 Adaptor |
Serial RJ-45 Pin # |
RS-232 Signal Pinout EIA/TIA-561 |
T568B Wire Color |
Connect to these lines on Serial End Device |
1 |
Data Set Ready (DSR) |
White/Orange |
Data Terminal Ready (DTR) |
2 |
Data Carrier Detect (DCD) |
Orange |
DSR/DTR line |
3 |
White/Green |
4 |
Signal Ground* (GND) |
Blue |
5 |
Receive Data* (RXD) |
White/Blue |
Transmit Data* (TXD) |
6 |
Green |
7 |
Clear to Send (CTS) |
White/Brown |
Request To Send (RTS) |
8 |
Brown |
