two radio ptp600 (1 connectorized and 1 integrated) may be associated with each other ?
there is some stuff to change and to do or must i rearm all radio with the mac of the other end ?
i must make a swap … so before creating some downtime i want to be sure …
thank you
Hi Spokke
Yes - Integrated and connectorised radios can be linked together without any problems.
A few things to check
- Both ODU’s should be running the same version of software
- You will need to change the target MAC address on both units with the new values
- You will be installing external antennas at one end - so will need to make sure that you go through the alignment procedure.
I would update your LINKPlanner project with the new antenna details - you will then see the predicted Rx values, and be able to check against these values when you complete the installation.
Regards
Julian
