Creating floorplans for a group of APs at one site.
We currently have a site set up in cnMaestro which has 3 floors with many access points. The floor plan that has been created is compressed as it shows all 3 floors and is hard to read and use.
I am trying to have 3 seperate floors set up so that we can see each individual floor plan clearly but still be able to look at the whole of the 3 floors as a whole and not have to analyse each floor individually for management. Is there a solutuon to this problem or do they have to be seperate?
Many Thanks
James
Hi James -- currently each Site only allows a single floor plan, so the Site aggregations are per-floor. We are planning to extend the Site concept to model a building, which would allow for many floors. I expect this functionality to be available this summer. If all devices in the building have the same configuration (i.e. map to the same AP Group), you could assign a dedicated AP Group to the devices . The AP Group Dashboard would provide similar aggregations to the Site Dashboard, though without the benefit of the building (yet).
Any news on multiple floor plan option?
Kind regards
Appreciate that Cambium invest time to support site with multiple building with multiple floor each
Hi!! 5 years from the first post and no multiple floors at the november 2022, it’s not necessary but…
Hi diegobbo – multiple floors are supported in a Site as an X feature.
what is the benefit of the floorplan? Is this feature is show visual coverage like heatmap ?
