Pls help to configure
| Security: | noneWPA-AESWPA2-AES | ||
| Authentication Type: | Open Shared Key | ||
| WEP Key Length: | 64 bit128 bit | Key Type: | HEXASCII |
| WEP Key: | Key Index: | 1234 | |
| WPA Authentication: | PSKEAPEAP-TTLSEAP-PEAPMSCHAPV2 | ||
| WPA Preshared Key: |
WPA-AES
WPA-AES
Hi raju,
I would be really appreciate it if you could clarify what exactly you are trying to configure.
Thank you.
hi,
I am trying connect ISP AP to get internet connection . ISP AP is runing WAP-AES Security
and showing regestered AP is not Asocciated showing scanning.
Hi raju,
SM which is going to be registered on AP should has same Security method configured as AP has.
When WPA2 is selected on AP, WPA2 Pre-shared Key should be configured as well.
Then same WPA2 Pre-shared Key should be entered on SM.
Also please verify SM has Frequency Carrier which is operation Frequency Carrier for AP in scan list.
Thank you.
hi,
i am connecting the AP with security pass key. pls help
@raju wrote:
hi,
Hi raju,
For immediate assistance, can you please contact our support engineers at support@cambiumnetworks.com? They can also be reached here: http://www.cambiumnetworks.com/support/contact-support/
I think it would be best to work with an engineer to troubleshoot this live.
Sriram
