CnMeastro Type = CnMeastro Essentials
Version = 4.1.0-r3
Issues:
I am currently facing problems with getting a client id and client secret to connect to “cnMaestro RESTful API” on v2. I have three problems I am facing right now
- How do I get the API Client navigation tab?
- How do I set the “client_id” and “client_secret” manually because I tried setting one and using it in API authorization header and it gave me an error?
- In the above(issue 2) can you choose to manually set “client_id” and “client_secret” over using the default “client_id” and “client_secret”?
