I would like to setup a profile in cnMaestro where I can override the SSID with something like "SSID_****" (**** = 4 last characters of MAC). There is the macro $(MSN) but it is the full MAC.Is there any way to do what I want to do ?Regards,Matheo.
Hi
We will upade you ASAP.
Regards
Niraj
Hi,Do you have any update ?
Regards,
Matheo.
Hi Matheoz,
Currently this option is not available in CnMaestro to configure SSID as per your requirement (SSID_**** (**** last four characters of MAC)).
You can use User-Defined Overrides like below to distinguish between SSID's broadcasted from different devices,
SSID1= SSID_%{ESN} ---(ESN will be replaced by device MAC)
or
SSID1=SSID_%{MSN} ---(MSN will be replaced by device Serial number)
Divakar
