Datasheets for Mounting Brackets
The Universal Wall Mount Bracket- Part Number: C000000L136A and Universal Pole Mount Bracket- Part Number: C000000L137A are constructed with Q235 Carbon Steel with a Geomet finish and are designed to operate at Temperatures of -40°C to +80°C.
They support a wide range of radios: 60GHz cnWave V5000, PTP550, PTP550E, PTP670, PTP48700, PTP78700, PMP450i Connectorized.
Attached below are the datasheets for C000000L136A and C000000L137A.
C000000L136A-Universal Wall Mount Bracket (71.6 KB)
C000000L137A-Universal Pole Mount Bracket (73.4 KB)
Is the C000000L136A Universal wall mount bracket compatible with the XV2-2T0XA00-US outdoor WAP and likewise will it mount on a single or double gang electrical box?
I was wondering if there is any antenna mounting bracket data sheet on the PMP 450v 4x4 Integrated Access Point, 90 Degree Sector Panel Antenna (C060045A403) and the PMP 450v 6 GHz 4x4 BH-SM Mechanical Dish Assembly (N060045D401). I am looking for the mounting pipe diameter that can work with these antennas.
