DC POE Injector for PMP450
I wonder if anybody out there can recommend a DC input POE injector for the PMP450 AP and SM.  We have some sites which have DC power and it would be good to get a solution that suits.
Eddie.
What voltage do you have available today?
SM's will take any voltage between 20VDC and 32VDC. Just take the standard PMP450 power supply and cut off the transformer.
The AP's will take 22VDC to 32VDC.
Sure that's what I currently do.  Is there a PC POE injector that can be used interchangeably between ePMP and PMP450 that does GigE?  (sorry i should have been more specific!!!)
Eddie.
Unfortunately not that does GigE.
Today we have two options:
1) The traditional Canopy PoE with the RJ45 pigtail. This can be used for either PMP450 or ePMP and can run directly off of a DC feed if the AC transformer is removed from the power supply. But it does not support GigE.
ACPSSW-09B-US Version
ACPSSW-13B-RoW Version
2) The newer Gigabit PoE brick which can be used for both PMP450 and ePMP but does not support DC input.
N000900L001A (Ships WITHOUT AC power cord.)
Thanks, Seth.  Most helpful.
