Has anyone used a DC power supply to power a CMMII? If so are you connecting to the DC connector on the board?
The directions in the manual are not real clear. There is a connection coming from the AC transformer to the board then a connection to the switch using DC. Is this were you connect your power supply?
Page 24 of the manual shows a diagram which says to remove the cable that runs between the AC power supply and the board when using DC. Plug the DC into the spot where the AC power once came from the power supply.
Page 29 identifies the options when using 12V or 24V DC.
Does this help?
Yes that helps but it seems confusing because the plug indicates the input is AC power. You are say apply DC 24v to this plug?
