Hi i was Trying to login into my Cambium Sector using default IP but i fail
192.168.0.1 and 196.254.1.1 i fail to Login
Anyone can help please ?
Hi Chagga,
I believe 196.254.1.1 is a typo error of 169.254.1.1. If not please try to access the radio using 169.254.1.1.
192.168.0.1 is for AP and 192.168.0.2 is for SM.
Please let us know if you are able to ping the radio IP.
If you are still facing the issue, then please contact the support team and we will assist you further.
Regards,
Sanjay Kumar.
Hi Chagga,
Also you can use hardware button on board to reset configuration to default.
Thank you.
