Default Plug
Hi everyone
I need to default a SM that I locked myself out of. I have read the KB article "How do you make a default plug?
" (http://motorola.canopywireless.com/supp … d=243&c=16) and it mentions a 6 pin RJ11, but any RJ11 plug I have looked at has only 4 pins. Am I looking at the wrong thing. Any help appreciated.
Regards
Eweda Maan
Eweda_Maan wrote:
Hi everyone
" (http://motorola.canopywireless.com/supp ... d=243&c=16) and it mentions a 6 pin RJ11, but any RJ11 plug I have looked at has only 4 pins. Am I looking at the wrong thing. Any help appreciated.
Regards
Eweda Maan
You need to get a 6 pin plug, physically it is the same size as a 4 pin RJ11 but has 6 pins. You should be able to pick these up at radio shack or any decent home center.
6 pin jacks are typically used in older PBX systems.
