Demonstration: Network Service Edge Starlink Integration
Starlink provides powerful satellite-based Internet service, and this demo shows how to secure and manage it with confidence. The Cambium Network Service Edge (NSE) adds Next-Gen Firewall, Application Visibility, and direct Starlink management for a unified and protected deployment.
In this demo, you will experience how Starlink can be monitored and managed directly from cnMaestro, creating a single point of control for your network. Along the way, we will highlight how NSE supports multiple dishes with effective load balancing, ensures fair traffic with Adaptive Queue Management, and provides content filtering that strengthens education environments.
This is a cool demo, however is there a PDF datasheet or something similar?
Tried the on-line Demo today and it had great info but for some reason every slide / screen change it would default the language to German, but I only speak English. Not sure way but I was using the latest Chrome Browser 145.0.7632.160.
Thank you for reporting this!!
This is the multi-language feature from our vendor, which auto-translates to a language based on the user’s location, which is annoying sometimes when you would like to view it in English. auto-translate is now turned off, so should be viewable in English only.
That fix the issue. I am in the US / Alaska so it should have been auto-translate to English. Th only odd PC issue is that my company uses ZScaller which tunnels all of my web traffic to Seattle / ZScaller IP gateway but that still should have auto mapped to Engish. But either way its fixed now. Thanks for the quick fix.
