Demonstration: Quick PTP links
See how easy it is to deploy high-speed, reliable wireless backhaul with Cambium Networks’ 60 GHz cnWave PTP Quick Link. This guided demo walks you through the streamlined setup process, helping you establish a high-capacity link in just minutes.
Will this work, if I already have an existing link and I want to use this process to add an additional CN to the POP?
Quick PTP is designed for PTP alone. It wont work for the second link.
However adding second link is straightforward
  1. Add the CN node
  2. Add the link between POP and the new node.
Can you tell us if you are using cnMaestro or device GUI ?
