Native Tagged^ Maps native VLAN traffic of device to untagged traffic on Ethernet (when enabled) otherwise keep it tagged on Ethernet side. Enable/Disable
The description is wrong. The configuration works as one would expect it to (check tagging and the native VLAN is now tagged on the Ethernet port), but the description says when it's enabled, it maps native VLAN traffic to untagged on the Ethernet interface.
Please correct this.
