Devices do not connect to cnMaestro. I moved several devices from one sector to another. Now all these devices are online, but they can't connect to cnMaestro. All devices have Internet access. I deleted one of the devices and added the serial number again in cnMaestro. Nothing has changed, either. I have the problem on force 300-19 with firmware 4.4.3. Previously I used 4.5, there was no such problem, but due to stability problems I had to roll back to the recommended version. cnMaestro - cloud. Sectors - ePMP 3000.
Hi Alex,
Which cnMaestro software version you are using and whether it is cloud or onPremises . Can you please get the logs from Device GUI -> Monitor ->System Log page with the options Syslog Display and Device Agent Logging Enabled .
KR.
What can I tell about my issue:
1 - the combination of ePMP3000 with FW 4.4.3 + Force 300-19 with FW 4.4.3 works stably. SMs in the cMaestro 2.4.1-r3 cloud is displayed as off-line.
2 - the combination of ePMP3000 with FW 4.5 + Force 300-19 with FW 4.5 is unstable. SMs in the cloud cMaestro 2.4.1-r3 shows the real status
3 - Combination of ePMP3000 with FW 4.5.4 RC16 + Force 300-19 with FW 4.5. 4rc16 works stably for 3 days. SMs in the cloud cMaestro 2.4.1-r3 shows the real status
Hi Alex,
Is your cloud connectivity issue resolved after changing to the device firmware 4.5.4 or you are still facing the issue. I have gone through the syslog messages but does not indicate any issue related to connectivity. If the issue still persists can you please raise a support ticket so that we can debug the issue further .
KR.
All problems with CnMaestro are resolved.
