Hello to all
I use the cnpilot e410 configured with the cloud cnMaestro,
I have configured the primary wlan (192.168.x.x), associated to the VLAN1, with the DHCP managed by the internal DC and it works correctly
I created the secondary WLAN (192.168.99.x) associated with the VLAN2, but I can not configure the DHCP managed by the ap?
sorry for my english but I use google translate.
thank you
Hi Tommy,
Greetings!!
From your query I understand that you are planning to use e410 as DHCP server to provide IPs for WLAN (192.168.99.x)
You need to create a DHCP pool and VLAN interface and map it to the WLAN (192.168.99.x)
Refer following link for better understanding:
Best Regards,
Gupta Bobby
the link does not work
I have configured DHCP, VLAN2,
but the AP does not communicate with the internet firewall .....
Hi Tommy1,
Please email tech-support to pvsr.gupta@cambiumnetworks.com
Thank You
