I’m back, being still a beginner with cambium I noticed that I often divvicolta ‘find on the net my cpe’ cause I do not remember the IP, it would be very helpful to me if there would be a tool discovery be installed on your PC to display products cambium, such as that for UBNT, I do not know if there is already 'you perhaps?
I would like to know if thers is an ip discovery tool created for Cambium devices?
You can check the following tool:
http://community.cambiumnetworks.com/t5/ePMP-Beta/Cambium-Discovery-Tool/m-p/70574#U70574
Thank you but I can't access the link.
You do not have sufficient privileges for this resource or its parent to perform this action.
Click your browser's Back button to continue.
That link is in the beta section. Please sign up to become a beta user here: https://support.cambiumnetworks.com/beta
