Do Cambium have a DAC cable solution for a PTP 850 radio?
I want to find out if there are any DAC cables available for the PTP 850 Radios for a 4+0 configuration? It might be cheaper than the SFP and Separate fiber solution?
I don’t believe Cambium sells or recommends any specific DAC’s. Their SFP guide is located here: https://www.cambiumnetworks.com/wp-content/uploads/2021/11/Cambium_Networks_data_sheet_SFP_Guide_09082021.pdf
We’ve had good luck using DAC’s from FS, although we’ve never used them with the PTP8X0 radios.
I think we will test and provide some feedback.
