Docker errors when installing Edge Controller
Trying to install edge controller on Ubuntu 22.0.4 as recommended.
Finishes install and asks for cnMaestro info but then always crashes with the following message.
“Docker compose apply failed”
Docker ver 24.0.5
Docker-compose ver 2.20.3
Hi @Martin_Keding,
The latest compose version and docker versions are having compatibility issues and due to which it is happening… working on the fix and will be available by this week end or mid of next week
Hi Sathwick,
Any updates on this issue? We are seeing the same problem in a new deployment.
Hi @Andrew_Link,
The compatibility issue has been fixed already, and we have published a new version of package. So all the recent installations should go through the fix.
Can you please share logs from /var/log/edge-controller/edge-controller.log file along with the installation CLI logs/screenshot to know more about the issue?
