Hi Cambium Community,
I have been running into a round of issues when using cnMaestro to manage a EX2010-P switch within my lab environment. The last time it was trying to get IPv6 to work through the switch, which I come to find out after checking with the Cambium team, it was not supported until a recent firmware update.
Now, I am trying to use the Switch Group feature to make changes and work through creating templates to use for rapid deployment and have been running into an issue which the EX2010-P is no long connecting to cnMaestro and I cannot make the changes from cnMaestro. The switch itself is online and available to connect through a web GUI through its IP address on the network, but I cannot factory default.
In terms of troubleshooting steps I have done the following:
- Removed it from the cnMaestro envornment and re-onboarded it
- Deleted the Switch Group that might have been causing the problem
- Clone the Default Switch Group and renamed it to something else as the basis for a known good configuration
- Added the EX2010-P to the new known good default switch group
What else should I done to get the EX2010-P working with cnMaestro correctly? Is there an bug/issue within cnMaestro and the cnMatrix firmware that is causing this issue?
