Does WM integrate with RADIUS?
WM does not integrate directly with RADIUS.  When deploying RADIUS with WM there are two options:
  1. Use RADIUS to authenticate the radios and provide provisioning of VLAN and QoS profiles.  This is useful in cases where an existing CRM or provisioning system has been integrated with the RADIUS solution to allow easy customer management and provisioning.
  2. Use RADIUS only to authenticate users, and use WM tempates to configure VLAN and QoS profiles.  This is useful when you want all your device configuration to be done using one tool, and not split the configuration amongst multiple tools.
