Hello -
If someone has a local cnMeastro, where is the domain proxy done?
Does the local server connect to the SAS, is it still through the cloud, or does the CBSD itself communciaste directly to the SAS?
Thank you
Hello -
Thank you
The domain proxy is always on the cloud even when connected through the local on-premises cnMaestro. Hence a CBRS enabled cloud account is mandatory and the same needs to be associated with the on-premises cnMaestro.
However, since the on-premises devices may not be connected directly to the internet, the on-premises cnMaestro can act as a http proxy, which will proxy the CBRS transactions to the cloud domain proxy. Alternatively an external http proxy can also be configured on the on-premises cnMaestro.
