Capping downlink MCS to “DS MCS 7 - 64-QAM 5/6” does not work on my cambium force 300-25l, the radio still uses more than that. The only way to make it work is if I use firmware from 4.7 upwards.
How can I make it work on firmware 4.6.1 or 4.6.2?
Hi @Atang_Maretele ,
4.6.1, 4.6.2 and 4.7.0 are quite old images. I suggest you to use our current stable release 5.10.4.
ISP epmp 3000 access point is running on 4.6.1
so what do you suggest?
@Atang_Maretele, I suggest you to use our current stable release 5.10.4.
If you still see any issue, please Raise Ticket in the top right of this page!
Our engineer will assist you to isolate it. Free of charge
