E400 and E410 together
Hi. I was wondering if E400 and E410 APs can co exist together and if the clients will easily roam between the two APs. Also would there be any downside in combining these two APs on one network. Thanks.
usps tracking showbox speed test
These AP's are virtually identical except for the E410's are AC wave2 compliant. You will need clients that support AC wave2 in order to take advantage of this feature. Yes the can coexist, and yes clients can roam between them. There's no downside to combining/managing these two AP's on one network. That being said, if you know that many or all of your clients are AC wave2 compliant, then you would be better off using all E410's.
