Hello, i have a Problem with my CN E410.
I want to use one as a Base and one as a Client in Mesh.
The Base one should be connected “Wired” on my PFsense and the Client will be connected with an POE Injector but no Uplink.
Okay if both are Wired i have a Mesh connection.
If i disconnect the Client it doesnt work with mesh.
You have to add to both
MESH SSID
CLIENT SSID
Your SSID.
Thats all
If it dosen’t work it could be to long distance, interferencje, wrong configuration.
