E500 and power with solar panel
Hello,
I must install some E500 on a mast and need to be powered with battery and solar panel.
What is the minimum voltage ? 48v, 24V, 12V  with passive POE ?
Thank you,
Alain
We support both 802.3af / at PoE standards. Follow the wattage / voltage as per the standards.
802.3af PoE Injector, or PoE switch.
802.3at or PoE+ if using PoE-Out Aux port.
Best Regards,
Gupta
Hi alain, we been using E500 on our solar power hotspots, depending on your solar system voltage you can choose between a TP-1248GDHP for a 12v solar system, if your voltage is 24v use a TP2448GDHP, if your voltaje is 48v you can use a TP4848GDHP
Hello,
Thank you for this system .
Alain
