Just looking to get some advise on how the best mount this unit. Should it be mounted horizontally or vertically?
Thanks.
- mount.png (120 KB)
Thanks.
It looks like this is an indoor application correct? If so, how high is the ceiling to the floor? If you want to cover below the AP the best way to mount would be with the e500 parallel with the floor (so rotate 90deg from what I see in the picture).
example pattern shown below with horizontal mounting.
a 3D pattern of one of the 5GHz antenna elements inside the e500 for reference.
Much appreciated Jim, we are making changes to the mounting now.
ok great. if any other questions please let us know
were you able to make the mounting adjustments? How is your coverage looking? any other quesitons that you have regarding mounting and/or antenna that we can help with?
