New the the Cambium WiFi world, Something I’ve often done with other vendors is using a mesh type feature to also bridge. EG a camera on a pole where I don’t have LAN.
I’ve got the mesh working, but connect a ethernet cable and it seems to drop it.
Is this possible with E510’s (or even the XV/XE series) or am I barking up the wrong tree?
So I manage to work it out, The main issue was the way Cambium Tech support told me how to do it in cnMaestro. They advised adding both mesh networks (Client and Base) to the same AP group.
By creating 2 groups it now works as intended.
Thanks to @TimoWanume for pointing me in the right direction by doing on the AP.
Great it worked for you.
The same connection is successful even when you use ether1(since e510 has only 1 ether port). But you will have to power the camera using a 12v power adaptor.
