Are these compatible?
We use the 6 mini and 12 port switches
Hi
Is your requirement is to power on the AP with the Netonix swithes? if so , please share the model number of the switch and the data sheet.
Regards
Anand
Yes, here you go.
ws-6-mini www.netonix.com/wisp-switch/ws-6-mini.html
ws-12-250-ac
https://www.netonix.com/wisp-switch/ws-12-250-ac.html
Both the WS-6- MINI and WS-12-250-AC can power up E700 as well as E505. Make sure that the max power consumption of the switch is not exeeding when multiple AP's are connected. Suggest you to configure 48V Power out on the switch.
Regards
Anand
Okay, Thanks!
If we have any issues I will post them here.
