Edge Controller Installation Guide
Edge Controller is an application hosted in a customer’s data center behind their firewall. It provides a generic framework for running edge services that interact directly with cnMaestro Cloud or On-Premises. The Edge Controller application supports SNMP device management for PTP 820/850.
cnMaestro Requirement
cnMaestro must be running 3.2.0 or higher to onboard and manage Edge Controller.
Prerequisites
The supported OS for installing Edge Controller are as follows:
  • Ubuntu 18.04, 20.04, and 22.04
  • CentOS 7, 8, and 9
Installing Edge Controller
Copy below command and run as root user on the supported OS mentioned above:
curl -sSL https://registry.cloud.cambiumnetworks.com/repository/raw-hosted/edge-controller/latest/install_edge_controller.sh | sudo bash
For more details please download the user guide from here https://support.cambiumnetworks.com/files/cnmaestro/#r2
Any possibility of supporting other SNMP devices using an Edge Controller
