I used TFTPD32, and at the moment it seems it worked very good.
I guess you should ask Cambium directly for the *:bin file.
Well, I already have the .bin for Elevete LHG5, can someone help me? What do I do with the .bin? How do I charge it to the LHG5?, thank you
I have tried to do it with the Tftp and the Elevate process begins, the LHG5 restarts, but when it returns it is in Mikrotik again. It is possible that it is the version of Routeros, I have tried it with version 6.40.8 and 6.44.5. Could it be that this is the problem?
Sorry how you got the .bin LHG 5, I'm about to try. can you send me please ?
I think you should ask Cambium
Hello people, I have a lot of LHG5 can I also have the .bin file and give it a try?
I used the imagen that send me cambium .elf but when reboot return routeros mikrotik, and i try to updeate whent its elavate but doe'nt accept the imagen.
this was the imagenĀ MIKROTIK-LHG5-initramfs-v4.3.2.1.elf
the new imagen thatĀ download in officila web cambium not work the same problemĀ
MIKROTIK-lhg5-elevate.elf
Hi!
DId you have a chance to try Device Elevator?
Dmitry
Hi Dmitry,
I'm trying to elevate LHG and RBDisc5 with Elevator Tool 29.44.xx but dosen't works.
Software connect to device via ssh, backup, device reboot, "elevating" message for a long time and finally : "no feedback from device".
Is possible elevate with this tool this devices? via wireless? I have more than 500 devices to elevate...Visit and do it manually is a big task.
Thanks in advance.
Resolved Elevate LHG5
Use this method with TFTP64 and this firmware
https://www.youtube.com/watch?v=G90VU-RPhjc&t=137s
https://drive.google.com/open?id=1G-YzcNyS71uIEBRwxeWn2Vspb6RRcyB1
Then enter your device already raised 192.168.0.2, and update it with the image: MIKROTIK-lhg5-v4.3.2.1.tar
If you don't update it, it will return to RouterOS.
Elevate the following models without problems:
LHG 5
LHG HP5
LHG XL HP5
Regards!
Can Cambium confirm Elevate on this devices:
LHG HP5
LHG XL HP5
Hi!
They are not fully tested but some customers reported that they work well.
Dmitry
Also please check new version of device elevator with the limited support of LHG5.
Dmitry
Hi, I have elevated Lhg with tftpd64 while I have problems with Device Elevator 30.44.
Please, could You send me last .bin file to elevate LHG 5 ?
Please, do I have to put it inside main Elevator tool directory with other xm and xw files?
Kind Regards
Hi Alberto,
Just grab device elevator from the following thread:
https://community.cambiumnetworks.com/t5/ePMP-Elevate/Device-Elevator-a-powerful-tool-for-your-network-lifting/td-p/75871/highlight/true
It already has everything built in for elevation.
Dmitry
Hi there
Which firmware needs to by on the LHG ? I can see on the logs of the LHG - "login failure for user devel" which means I either need to add a devel user for this to work, or it is based on a previous version of the firmware.
The latest LHG5 version I got does not have the ability to install 6.40.x software so it is not possible to install elevates? I get the message that the board does not support this version.
Is there any solution to this?
Have you noticed config clear after update FW on Eleveated LHG, I have noticed form 4.4.3 to 4.5RC54
hello,
have you solved this? I suppose that I have the same problem
Tks
Best
Necesitamos migrar a Cambium. yo ya eh comprado todo un sistema epmp3000Ā para migrar mi red mikrotik con mas de 80 lhg5. Cambium ofrece esta posibilidad y nos proporciona las licencias elevate. pero no nos da un procedimiento claro de como hacer esta migracion.Ā
