Hi, where can I find the emission codes for the following:
- 13 Ghz PTP13820S
- 11 GHz PTP11820S (Wide)
- 11 GHz PTP11820S
Hi Aaron,
Not sure of your location but if you are making application for spectrum with the ACMA - then the following will help.
80M0D1DW - 80MHz wide channel - The PTP820S Wide 11GHz radio supports an 80MHz channel. FYI, The PTP820S Wide can also support a 40MHz wide channel.
40M0D1DW - 40MHz wide channel - The PTP820S 11GHz radio supports a 40MHz channel
28M0D1DW - 28MHz wide channel - The PTP820S 13GHz radio supports a 28MHz channel
Not from this part of the world - Apologies in the info above is not suitable.
BMS
Thanks Brook, greatly appreciated.
