I want to activate AirTime on all APs, but cnMaestro does not offer this.
Does anyone know of a script that I can deploy from AP profiles?
Edu
Edu
We will have to declare this award void.
The question is that I have not been able to activate Airtime from any interface, from cnMaestro it does not exist, and from the AP itself the option is disabled immediately after activating it, I guess overwritten by cnMaestro.
Anyway, it seems that this will not be possible, at least for now.
Have you tried to get the backup file of one AP in stand-alone mode where the feature has been enabled, identify the variable that controls that feature, and, with this information, create a script in cnMaestro?
The configuration file does not report this.
I think I was able to enable Airtime via SSH, but I cannot confirm that it is enabled correctly, the web interface is very confusing, no matter if I enable or disable the feature via SSH, the corresponding radio page reports that it is not enabled, or yes, if you enable the feature in CLI, it also does not report if it has been applied correctly, “show config” also does not report this, all this is a mystery to me.
@Edues
Which model of APs have you deployed?
