We have tested and requalified the data rate supported on the following PoE injectors:
| Cambium PN | Change |
| N000900L001D | 15W 30V 1GbE → 2.5GbE |
| N000900L017B | 15W 56V 1GbE → 5 GbE |
| N000000L034B | 30W 56V 1GbE → 5 GbE |
The mechanical and electrical specifications remain unchanged for the three models. PoE injectors already deployed in the field will also support the enhanced data rates. The white pad print on the PoE injectors will be updated to reflect the enhanced data rate support.
Updated Datasheet
N000900L001D
N000900L017B
N000000L034B
