Hi
Am here to inquire whether Cambium has enterprise routers.
I need a router that can do vlan routing and natting
They have L3 switches (2k series) which can do vlan routing but they are not routers.
Check documentaion and see which features are possible and then see if that product can do stuff that you need.
E.g. cnmatrix doesnt support NAT
Thanks @mixig
I needed to know exactly about natting.
So that means, I will need a 3rd party router for natting
Yep, my choice is Mikrotik
