Software release 6.5.2.1 is available for Enterprise Wi-Fi. 6.5.2.1 software release contains enhancements, and bug fixes. Following are the downloads available for software release 6.5.2.1.
For more information on Enhancements, Fixed Issues and Known Issues, please refer Release Notes
Fixed Issues
- FLCN-14238: Memory leak observed when Auto-VLAN feature was enabled in the APs when LLDP frames received.
- FLCN-14235: Static channel configuration failed due to internal cross validation of same channel on other radio
- FLCN-14233: When GTK per VLAN feature is enabled, while multiple clients are associated to an AP with different VLANs, the GTK assignment goes wrong. As a result, clients on different VLANs can see each other, and clients on the same VLAN cannot see each other. This is not seen across APs.
Please READ “Release Notes” for the upgrade guidelines.
