Software release 6.5.3 is available for Enterprise Wi-Fi. 6.5.3 software release contains bug fixes. Following are the downloads available for software release 6.5.3.
For more information on Fixed Issues and Known Issues, please refer Release Notes
`Snippet of Fixed Issues
Tracking | Platforms | Description |
FLCN-14420 | All | LLDP caused memory leak when APs were deployed with non-Cambium vendor switches. |
FLCN-14339 | All | In a WLAN profile, when RADIUS and ePSK are enabled, invalid events were generated. |
FLCN-14294 | All | SNMP community parameters were not persistent across reboots. |
FLCN-14237 | XV3-8 | Deauthentication of client due to session timeout will be triggered only if it is learned from the RADIUS server. |
FLCN-14225 | All | The SNMP OID 1.3.6.1.4.1.17713.22.1.1.1.14.0 (cambiumAPTotalClients.0) always returned a value of zero even when clients were connected to the AP. |
FLCN-13911 | XE3-4, XE5-8 | OCS scan was not triggering for radio 3 if both radio 2 and radio 3 were configured as 5 GHz. |
FLCN-13882 | XE3-4 | APs continuously rebooted because of failure in unexpected boot parameter. |
FLCN-13672 | All | Erroneous time stamp was displayed for last-reboot-reason . |
FLCN-13631 | All | AirTime stats were not available for Tx, Rx, busy, and interferences parameters. |
FLCN-13292 | All | The static VLAN pool was not working when WPA2-Enterprise security was enabled. |
