ePMP 1000 2.4GHz Won't Pass Traffic After Upgrade Past 3.5.6
Hi All,
Has anyone else had an issue with ePMP 1000 2.4GHz not passing traffic after an upgrade past 3.5.6? The wireless will stay connected but the radio will no longer pass traffic. I have 3) 2.4GHz APs at the same site. I’ve had 2 upgraded to 4.6.1 for awhile with no issue but one seems to not upgrade properly. I believed the issue to be the radio but after a climb and radio changed out for a new one the issue still persists. The ethernet connection is at 1Gbps and all are connected to the same PPPoE server so I’m at a loss of what could be the issue.
I’m wondering if there’s some sort of carry over configuration item that is getting stuck. You might consider trying to update to 5.9.2, and then if you’re still having issues, reset the radio to factory defaults and configure from scratch.
Eric,
Thank you for the response. I did take a backup off the old radio and load on to the new one so your thought does make sense. I will compare the config to others on the network. I’ve tried several different versions as far as updates so I do know anything above 3.5.6 causes the issue.
It seems to maybe have something to do with Watchdog. I’ve now raised a ticket.
