Can anyone tell me what the difference is between these two antennas? I'm fixing to order some equipment, and just want to make sure that I get the most bang for my buck. I have a PO Request in for the ePMP 2000 sector antennas, just want to make sure they will work as I 'm hoping.
The ePMP 1000 sectors are EOL and no more stock will be available in the future. The 2000 sector has 3dBi additional gain and a better front to back ratio.
You will be much better off going with the ePMP 2000 sector.
