I'm new to Cambium - one of our field techs recommended we use them to bridge our two office locations. It's not going smoothly, but it could be user error.
Here's our setup:
Both radios are fully updated to 4.3.2.1
Main LAN with DHCP <---> ePMP AP | ePTP master <---------> ePMP SM | ePTP slave | bridge <---> remote office
We want everyone on the same LAN and subnet. I will be creating some VLANs later, but right now just a basic bridge with full LAN functionality would be nice.
What works:
The ePMP radios see each other and connect. I can log in to the web config pages of each radio.
Devices with static IPs work just fine, are visible across the LAN and have Internet access.
What doesn't work:
Devices needing DHCP assignment are unable to get an address
What I've tried:
Broadcast packet limit
DHCP Option 82
Unicast packets
Firewall Layer 3 rules to specifically allow port 67 and 68 on the LAN of each radio
Thanks for taking time to read -- and I appreciate any help you may offer.
Hi. If both of these radios are ePMP1000 series, then I’d recommend firmware 3.5.6 on them. Version 4.x is designed for compatibility between ePMP3000 / Force300s, with older ePMP generations. If you are all 1000 series with no 300 / 3000 in the mix, then 3.5.6 is most mature and full featured firmware
From there… I’m not sure we did anything special in our building-to-building bridges. Càmbium actually makes a “bridge in a box” which comes preconfigured for this purpose, but is really just two ePMPs config’d properly.
I've tried downgrading one end to 3.5.6, and the link says it's up but now I can't access the config page. I can get to my managed switch on the other side. I'll go to the other shop to power cycle the radio I downgraded. I'll post an update shortly...
-- Edit --
ssh was still working, so I rebooted and found that the downgrade did not happen. But the web interface works again.
@ninedd (or anyone) -- do you know if there is a good config document that might help me? We are using radios from the 'bridge in a box' kit, but I don't know what the co-worker did to them before I found our DHCP problem.
It also does not seem that the radios will take a downgrade.
