I have an epmp 1000, but I can not get device claim in the cn maestro, below the error.
Failed: Invalid Serial Number (s). Learn how to locate Serial Numbers.
Other antennas that I have, like the epmp 2000 and the force 180 are normal
OBS: The number is correct, I checked several times
Fedor
(Fedor)
May 10, 2017, 6:57am
#2
Hi Daniel,
Are you trying to claim device from cnMaestro using MSN or MAC address?
You can check Serial Number on Monitor -> System page on UI.
Old devices which were produced before cnMaestro support should be registered in cnMaestro using cambium-id which can be configured on device's UI.
In case your ePMP1000 has Serial Number please contact me at fedor.trutsko(at)cambiumnetworks(dot)com.
Thank you.
Fedor
(Fedor)
May 12, 2017, 7:07am
#3
Hi Daniel,
Looks like your ePMP1000 device has 11-character MSN from first generation which are currently not fully supported in cnMaestro. Today cnMaestro supports only 12-character MSNs.
Please register current device using Cambium ID from ePMP UI.
Thank you.
Hi i have 4 epmp 1000 never registered, im totally new using cambium this radios was stored , but i dont know where to start
Software Version
2.3.4
Firmware Version
U-Boot 9344_PX 1.1.4.a (Dec 31 2014 - 16:33:35)
how claim and register because this firmware dont have registration to cloud to my cnmaestro account.
kind regards
ninedd
(ninedd)
August 27, 2020, 3:04am
#5
ramseslinux:
…Version 2.3.4
The oldest software version you should be using is at least 3.5.2 (or 3.5.6).
