Hello, so I have been trying to set up the Cambium ePMP 1000 Hotspot.I have this issue that beats me.When I assume the site (which needs approx. 35Meters of Ethernet cable) and connect the ePMP 1000,best case scenario,i get one reply when i ping the IP,followed by time-outs.Disregarding the site setup,i use a shorter ethernet cable,not more than 2 Meters,and ping i get replies as expected,and hence i can login using the default IP and configure the ePMP 1000 Hotspot.
What seems to be fault here?
NB:The 35m ethernet cable isn't damaged.
